04.05.2007, 03:05 PM
~19:1 is a fairly typical final ratio for a MT with those sized tires (which I think are 5.65" IIRC for standard MT tires). Shouldn't be bad at all even locked into second gear. Of course, I'm assuming your motor will be the typical XL size motor found in the RCM store. If it is an L size, the two speed might be better off.
:Off topic: If you know the gear tooth counts of the diff ring/pinion, and the tooth counts of the tranny gears, I'd appreciate those numbers to I can add them to the speed calculator presets.
