Cartwheels
04.12.2007, 01:09 AM
Originally Posted by MetalMan
Discharge the pack completely (a charger set to discharge in NiMh mode), and then put a resistor with a small resistance on the pack when you discharged it as far as you can with a charger. A lightbulb would also work.
Leave the pack on with the resistor (or lightbulb) for a day or so.
How do you do the resistor trick. I would imagine you would want to discharge the pack pretty low first. What voltage is OK for resisters? I have some 150 Ohm 1/2 watt resistors. Would those work alright?
