MikeyLikesItSI
04.13.2007, 06:28 PM
I can adjust endpoints (MX3 radio setup). This radio combo is the only one i've programmed/used with the ESC. I tried backing the EPA on the transmitter to 90%, the difference was almost none
Does anything need to be changed when using a 4 pole motor? I had that BEC problem with it but i don't think it would have effected the controller (seperate circuit), besides, the BEC still works.
Also, the MGM manual states that automatic timing should not be used with high inductance motors (5 or 10 deg should be used). Is the Neu 1515 1y considered high or low inductance?
T-MAXX - MGM 16016 - Neu 1515 1Y - 2x 6000mah 2s2p
RC10TC4 - MGM 8012 - C.C. 540 5700kv
Mini-Quake - C.C. Mamba Competition Package - 2s 1450mah
RC10T - Novak Super Stock BL setup
