MetalMan
MetalMan's Avatar
07.11.2005, 11:01 PM
The 3s will be quite a load on the Feigao 6s. Also, because of the high voltage, the amp draw will go up, so that will make the motor get hotter, and it would definately get the speed control hot. It would surely take your T4 to or past 60mph. Also, you would have to make sure that any Lipo batteries you get can handle the amp draw. I estimate that at full throttle (loaded), the motor will spin at around 63,000 RPM. That is considerably higher than the motor's rated limit of 50,000 RPM.
