Pros and Cons
GorillaMaxx360
GorillaMaxx360's Avatar
Pros and Cons - 06.16.2007, 11:39 PM
I was looking at buying a super brain 977 and i wanted to know your guys experience with it. I was going to get an ice but this charges 2 batteries at once and seems more economical for my 2 pack applications (Emaxx). with the brain i would cut charging time in half on some 2packs of lipos. does this charge max amps batts well? how easy is it to use? how many cells (lipo and nimah)can it charge at one time (per single battery plug, meaning for example if you where charging two batts up to how many cells could you charge on each lead). Any thing i should know and how does this compare to an ice because i can get it about one hundred bucks cheaper because i don't need a power supply.
