Just go Play
Just go Play's Avatar
06.11.2008, 12:43 AM
I didn't see it mentioned anywhere but what do you have the motor timing set at? If it is not at the lowest setting give that a try.
If you do end up cooking the motor you may want to try the velineon motor with your 3s lipos. You should be able to gear up to get more then enough speed to smoke the neighborhood revos with that setup.
