Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
doo540
01.29.2009, 05:46 PM
Well the stock rear-end ratio is 3.31
The stock ratio of the 3 speed in high gear is 1.53 to 1
Kershaw Direct drive is 45 diff gear with a 18 tooth center gear=2.50 to 1
If you use all of these numbers, compare your old setup with your new setup, or just pick a speed you want to run, you can then pick your pinion size.
I need to run a 27 tooth (from a previous 16 tooth) to mantain the same speed (48 mph)
I'm also running a Neu 1515 1Y on 4s until my 6s shows up in the mail.
