03.20.2009, 02:28 PM
Originally Posted by Unsullied_Spy View Post
3080 is over $1,000 last I checked. Bolidos are harder to get than a Neu, expensive, bad service/customer care, etc. 10mm shaft is actually a good thing, all 1/5th scale pinions I've seen are 10mm shaft.
You can get 12 and 14t pinion with 8mm bore. The 1521 motors I have here have 8mm shafts, so the 12t pinions will be used on 10s to get around 50mph.
On a side note I cleaned the carb and reset it to factory. After a few tugs it started up. So I will put it back together and setup the radio. Hopefully I can run it tonight or tomorrow.
