lutach
lutach's Avatar
04.07.2009, 07:53 PM
Do you have any specs on it? Like kv, max rpm, max current/power, etc?
Not sure what model he has, but here is a spec of the 1PV5135WS14 model:
Make/Model: Siemens, 1PV5135WS14 induction
Type: 3 phase EV AC PM synchronous motor
Rated / max voltage: 215V / 380V
Rated / max Power: 45 kW 61.1hp / 78.4kW 106.6hp
Rated / max RPM: 3,500 / 9,700
Rated / max torque: 120 Nm 89 ft-lb / 190 Nm 140 ft-lb
Max current: 400 A peak 282 A rms
Dimensions mm: 425x245 x245
Weight (motor only): 91 kg 200 lb
The inverter was the Siemens Simovert short (6SV-1) and here are the specs:
Maximum power: 100 kW
Max input voltage: 380 V ±2%
Input voltage range, nom*: 110...350 VDC
Input (battery) current max: 282 A
PWM Switching frequency: 6 kHz
Output current, max (RMS/peak): 282/400 A
Size and weight (aproximately): 25x10x5.5 59lb
Efficiency: 92%
Main contactors: In separate box
DC-DC converter: Integrated
Protection: IP-54
