NEU MOTORS : Lost quality and bad design !!!
SYLVERIS
SYLVERIS's Avatar
NEU MOTORS : Lost quality and bad design !!! - 04.09.2009, 10:47 AM
Ok BrianG , I'm sorry you are right, I have change some things because it wasn't so correct ... I was so disappointed, then...
And because I'm sorry I will post you many things it happen to me from the beginning, and I think you will have a loud laugh, the last bad thing I have is an Esc out or order !!!! Then I have to be honest too, I think I'm a total unlucky man, will explain later...
Corrected post :
Hi, I have a new Neu 1515/1.5D/F with the new design ! As you maybe know now, the new model has a front end cover which is a different part as the motor can !!! I have seen after only 3 times of use, that this front end cover is moving because it's hasn't been tighten well by Neu ! There is a little screw to prevent unscrewing but this screw was not tighten too ! I decided to fix the front end cover with Loctite but I have to drill an other hole for the little screw ( wich prevent unscrewing ). I want to do it myself, but I'm afraid ! I have send a message to Neu and like everybody, they said me to send them my motor !!!
I have seen now the front bearing seems to be out too ( wear, play ) !!!
How do you want to fix a motor via this front end cover without any issue !!!!
What will I do ? Send my motor to Neu, like many people, because their bearings are bad !!! I know a problem with bearing is possible but they will have too, to drill my motor to fix the little screw who prevent unscrewing and I'm very septic with this can design... A guy said , they are great with customer service... I know they can change me the front bearing if it has a problem, but is anybody of you had already received and test the new bearing ? Is it ok now ? !!! Only them can change a bearing ? It's an embarrassing situation to send them, but not to send us the bearing ! I'm so furious because I have seen it run well and I know this Neu it really powerfull....but those motors are very expensive, and this new design is a total error !!!
Sylvéris is online now Report Post Edit/Delete Message
