spcpicard
06.22.2009, 10:41 AM
Since I've sold all my nitro stuff, I still have a nice jr9100s HV servo laying around, this is the all aluminum case with .06 speed and 230oz of torque. I was planning to use it but with only 6 volts coming from the bec it's specs drop down to the normal 9100 180/.06. If I install the CCbec so I can boost the voltage going to the servo, will there be any pros or cons using it instead of the built in bec on the monster? If I do go with the cc bec, is the installation the same as with the MM, just remove the middle wire comming from the esc?
