zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.02.2009, 05:03 PM
Originally Posted by gyn77 View Post
I also thought to buy 23mm hex, but the problem was that I cannot replace the same Front Width 18.1" (460mm) and Rear Width 18.9" (480mm) of baja because savage braces are not so long as baja braces.
So I thought homemade adaptor was the best way.
You know what, I am so sure now that the standard 17mm hubs are stronger than the 23mm units. The 17mm's hold the axles better and spread the load out pretty good on the axle. A 23mm on the other hand, causes pressure points on the axle, causing higher stress... plus they wobble alot more than a 17mm.
I am not sure this helps you though?
