Go Back   RC-Monster Forums > Support Forums > Novak
ta_man
12.11.2009, 02:29 AM
Originally Posted by NovakTwo View Post
We could always offer a "Build-A-HV" program....
And a "Build-A-Crawler" program....
How are your 8.5 HVs working? Bob is concerned that the lower Kv B. motors, from using the 14mm rotors, might not work very well.
We can easily offer higher Ballistic 550 wound stators.
If we decide to offer the Ballistic 550, the price would be under 110.00, which is the price of our HV Pro motor, which it would replace.
To be honest, I haven't had time to play with it yet. I definitley would not put the 14MM rotor in it unless it was to be run on 5S or 6S. Actually, I have the 8.5HV earmarked for a 4X4 slash on 3S with the standard 12.3MM rotor. I figure it will give me a lot of gearing flexibility and still run cool. I've been running a 7.5HV on 3s (with a Havoc3S) in a CRT.5. It goes plenty fast enough for the track where I run, the motor barely gets warm (10-15 degrees above ambient) and the speedo stays cooler than the motor. Feel the speedo heatsink after running the car and you can't even tell it has been turned on (that is with the fan on it, of course).
