01.07.2010, 03:51 AM
The CRT mount looks closest. If nobody just knows what fits, sending Mike some dimensions should get you what you need.
You'd need:
The height of the diff braces
The distance center to center of the screw holes in the diff brace, both top and bottom.
You'll have to cut up the top plate to remove the gas tank area and the brake servo if you won't use it. Looks like an easy conversion.
