Junior monster
hooppjs
RC-Monster Stock Maggot
hooppjs's Avatar
Junior monster - 01.20.2010, 12:35 AM
Gday,
I thought this little 1/18 car would be my 3rd and FINAL fast electric car, but I was wrong. There is another.
I wanted to run the Xray before I blabbed about it and the electronics of course. Not sure if any of you guys are too interested, but here I go.
The car is 1/18 scale, Xray M18Pro. 220mm long, weighs 413 grams with battery & shell. Onroad, shaft 4wd, tiny shocks & foams. I'm using Spektrum DX3, C/C's 6800/micro pro setup, Hitec HS82MG and 2s lipo.
Instructions told me to run the car in gently whilst adjusting the front and rear diffs about 4 times. Started doing some high speed runs after that. Settled on 14/42 gearing.
I purchased 2 lipos from hobbycity, both rhinos 2s lipo. One is 40c 1050MaH and the other 20c 1750MaH. I really like the 40c battery:) They were about $9US each? Perfect fit for the car, very small and powerful.
I still have the composite drive shafts and they are holding well. Same with plastic pinions holding up to 6800kv power. I put some thin mesh gauze under the motor hole with double sided tape to stop small pebbles denting the CC can and the beautiful ali drive shaft.
The body shell is a Mazda 626. I could not help myself at the LHS where they had little wipers and rear mirrors, so I bolted them on too. I have ordered a high downforce lola type body for it already. I also put the tiniest YR fan on it I could find. Held on with very sticky double sided tape. It has not budged yet.
I'm happy all the electronics got crammed in no problems. Nothing drags or touches the shaft. The chassis has adjustable sliders for the battery.
I do like my 1/8 brushless landmax, as it is a big lump of iron being thrown around, but this little thing keeps me on my toes for sure. Absolute blast to drive, razor sharp and sticks to the ground. I especially like how you can get on the power very early exiting corners and just power out on your line under complete control. It goes around happily at 1/2 to 3/4 throttle, then when pressed it accelerates to demonic speed. These little cars are insane. No problems with anything yet. I bought some spares for when things crap out.
No data logging as nothing will fit. That's it. I hope you like it.
Peter
2s lipos next to the 5s Landmax beast lipo
100% recycled electrons were used in this message.
