reno911
Smelly Nitro meet your maker!
reno911's Avatar
03.02.2010, 01:56 AM
Originally Posted by reno911 View Post
Mikes mount comes with a spacer for the other side of the diff. Raising the diff so you can flip it around on the chassis and clear it since there is no hole on that side. The tekno chassis has the hole on that side since the kit is designed to flip the diff. So in short yes they will be a perfect match.
Ate my words here. The RCM mount and the tekno chassis are not compatible. I will be calling tomorrow to see what can be done.
RCM mount flips only the differential, whereas the Tekno flips the diff and the two diff mounts. Making the larger diff mount face the rear and the smaller mount, which used to be in the rear, which is replaced by the RCM mount, is in the front.
So the RCM mount now replaces my front diff mount which isn't what I need. Nor am I going to hack up the nice Tekno chassis to make it work. I will call and see if it is possible to have one made for the larger diff mount.
