Go Back   RC-Monster Forums > Support Forums > Team Tekin
itbvolks
04.07.2010, 05:18 PM
43mph is certainly pretty quick for track use. I'd guess the nitro guys are running 35-40 with most truggies so you should have room to come down (gear up) in pinion size. 15T would still pull 40mph and should decrease the current pull on the motor...
I'll be interested to see what mine pulls as I'm running the same setup (1700kv @ 18.5v geared 16/46) but in an MBX6T. I'm running Hyperion 4200mah 35c's though. Truck weight RTR should be under 9.5lbs....
