04.22.2010, 04:07 PM
Rather radom but the technical drawing still shows the fan:
http://www.castlecreations.com/suppo...ro-onecell.pdf
Also the text says :
"These controllers will have their BEC circuit disabled -- removed actually -- so you will need an outboard 4.8 - 6.0 volt power source to run your electronics. We recommend a CC BEC or CC BEC Pro. "
Isn't that a touch pointless as running on 1 cell you need a voltage step up device such as the Novak boost to get to 5/6v...
Also says "We’ve also taken the fans off so users have an easier time squeezing them into tight confines" so adding a CC BEC Pro (which is about the same size as a MMPro) would be a little pointless...
PS Yes I'm having one of those afternoons.
