09.07.2010, 10:30 PM
Not sure what motor you are running, but I did 73mph with a box stock tamiya tt-01 (100 dollar kit), with bearings, a feigao 380 6s, MM, 3s maxamps 4000mah (yeah, it actually provided enough juice to do this, repeatedly), and foams. I did use a 10th scale gas body (200 mm, wide enough to not have to cut the wheel openings and still steer), Lola style shape. I had so much down force on the reat I had to put shock shaft spacers or the rear of the car would squat over 50mph and rub.
As far as your car making it into a mag, I think you will do just fine. They publish all kinds of stuff, even clean stock rcs.
Tags
brushless, mph, tc3
