Amazng
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Amazng - 09.25.2011, 04:43 PM
Your truck looks amazing. You did a great job and you have somethng to be proud of for sure. The issue you are having seems to be pretty common and I am sure that most of us have run into this issue at one time or another. How about trying to use just one servo and then the other to see if it is one servo or both that are giving you the problem. Are you using a BEC, or just running both servos off of the ESC? Running two servos on the ESC might just be too much servo draw to deal with. Especially if they are high torque servos. I have had servo issues myself and still do not quite get how different some servos are when all the specs seem to be the same. The other thing that I believe you are going to have a problems with is using aluminum rims under power. Super-glue just does not stick too well to aluminum, and they will seperate fairly easy under load. There are several threads inhere about using beadlock rims, balancing wheels, and also taping the tires to prevent balooning whih yu will more than likely see if you use a good range of power, torque, and speed.
SUPERMAXX YOUR LIFE.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
