quick lipo question
supermaxx4190
supermaxx4190's Avatar
quick lipo question - 05.24.2005, 09:26 PM
i have been looking at lipo packs and found some polyquest ones that i think will be perfect. They are the 4400 with 12C-16C discharge. that means they could handle 53 amps cont. 70.4 max amps. i would run one 2s pack and one 3s pack, which makes 18.5 volts (a little more than 15 nimh cells). im not sure if they would hold up to the 10L motor. accoring to the specs the 10L only draws 61 amps (not sure if it always draws 61 amps), and the batts are good for about 53 cont-71 max amps. Would these packs safley work with the 10L? thanks
BTW... The 2s pack is $95 and the 3s pack is only $140.
