Heres The List
GorillaMaxx360
GorillaMaxx360's Avatar
Smile Heres The List - 12.18.2006, 09:37 PM
HERES the list ( i might have forgot a few thing but if i did not much was forgotten i even added in the type of grease necessary to fill the diffs and the oil necessary to oil the shocks every think is pretty much here if i did forget something it is most likely small and cheap because i looked at a maxx as i made this list and i went through every part at the most i am probably missing 7 things from this list for it to be ready to hit the track after its build (these 7 things might be as little as a few washers, some lubricant and other odds and ends)
ULTIMATE MAXX
1.) Unlimited Engineering Racer X suspension pro kit.
2.) Unlimited Engineering Ger 4 servo saver steering assembly
3.) Unlimited Engineering Racer X shock kit
4.) Unlimited Engineering 8mm CVDS with 23mm hex Hubs
5.) External Ubec (on RC monster)
6.) GorillaMaxx Carbon Fiber Chassis
8.) GorillaMaxx Carbon Fiber Chassis Extension
9.) GorillaMaxx Racing skids
10.) GorillaMaxx G3 Battery Straps
11.) Fast Lane Machine Hybrid Bulk Head Braces
12.) HB Lightning diffs (purchase 2)
13.) RC monster Slipperiential
14.) DUH engineering titanium shock towers (DUH engineering.com)
15.) Revo slipper pressure plate
16.) Revo slipper rebuild kit
17.) Revo 36t spur gear
18.) Proline 23mm standard size Maxx rims
19.) Proline crime fighter standard size tires
20.) Proline medium blend glue
21.) RC Screwz E-Maxx screw kit
22.) ACER Racing E-Maxx Bearing Kit
23.) Lehner 1950/6 high amp motor
24.) 20150 Brushless speed control
25.) Maxx amps (purchase 2) 8000 mah 2 cell lipo batteries
26.) Hitec 5955TG titanium gear servo
27.) Spectrum DX3.0 Radio
28.) RC monster Heat sink
29.) (2) 40mm fans
30.) 70 weight shock oil
31.) Associated black grease
32.) RPM bumper with plastic stock E-Maxx mounts
33.) Durtraxx ice charger
34.) Ofna 12v power supply for charger
35.) 8 AA batteries for radio
36.) misc wrenches like hex wrenches
37.) and a 15t pinion get a higher pinion for more speed (this pinion will get you in the 30s)
38.) Unlimited Engineeting VBS bulk set
39.) Proline power strokes
That is all i can think of YOU WILL HAVE TONS OF FUN AND IF YOU ARE A GOOD DRIVER WITH THIS SETUP YOU WILL SMOKE THE GUYS YOU ARE RACING WITH :027: :027: :027:
