02.07.2007, 07:18 PM
I just got back from the track. I dropped the pinion from 46-13 to 46- 11 & it still stopped. So i called castle creations & talked to JOE FORD he was very helpful. He told me to try the following i order #1 when the car stops go to neutural immedaitly then pull the trigger to full throttle if it lurchs foward then stops reapete if it does it again then this means the LVC kicks in. He said even with the LVC turned it will still cut the power at 2.5v. He also said to drop my gear even lower. I dropped it by two teeth already & did'nt notice ant loss in speed. He said it sounds like it still might be overgeard, sinice i did'nt notice any loss in speed when dropping from 46-13 to 46-11. So i guess i'll have to get mike to make a adapter for my mugen diff.
