03.13.2007, 09:28 PM
I will answer your question and no slamming. :)
You can only run a 2s pack with the 7700. Keep them light which means it has to be a good pack. I would recomend a single flightpower 2s 4900 pack. Then make your emaxx as light as possible and run in only in first gear... and geared as low as you can get it.
Run stock tires or similar light tires (nothing huge like 40's moabs etc...)
BTW, this is absolutely the best forum for brushless info... the guys are only trying to help.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
