04.16.2007, 09:31 PM
When it gets wet/damp, it expands. At any rate, wood simply does not have the density and hardness of metal or even some plastics.
If it's very easy to work with, maybe make some mock-ups of an idea instead of using relatively expensive metal. But to actually use it; I wouldn't.
Procharged5.0
Procharged5.0's Avatar
04.17.2007, 10:11 AM
+1
I've used wood for mock-ups and for templates but you need a metal or thermoplastic material for "the real thing".
HotnCold
HotnCold's Avatar
04.17.2007, 04:21 PM
Good call Skellyo - thats what mike and i use when prototyping parts - A thick HDPE milled out to hold batteries works wonders... Good call
Hows that "Hope and Change" working out for Ya???
skellyo
skellyo's Avatar
04.17.2007, 08:10 PM
Thanks...I've got some of it sitting here ready to make my own battery trays with it soon. I just went with 1/2" though, planning to sink the batts into it about 1/4".
HotnCold
HotnCold's Avatar
04.18.2007, 07:30 AM
You could also get some 1" - and pocket it out and then use some smaller plastic and make a cover.....
