IBJAMMIN
IBJAMMIN's Avatar
04.19.2007, 11:41 AM
3s or 4s? trust me you dont need 4s this thing is a rocket on 3s I clocked mine at 56mph yesterday with a MM5700 and a Maxamps 3s 4000hv pack.:005:
Build tips 60wt oil in the shocks and fill the diffs mine were skimpy on the fluids. :)
You can see Jays setup for the Canadian nats at www.jamminproducts.com he removed the front swaybar? and I believe this is his CRT.5 in this vid www.5spoke.com/site/op/media/...41/fileid/8012
Check out Mikes Jammin buggy mount I used a aluminum Jammin buggy diff mount I had and bolted my motor plate to the brake holes to get the plastic Kyosho spur to fit. So with mikes mount you can adapt the Kyosho spur and mount the motor with relocating the rear diff mount holes in the chassis. :032:
Name:	e crt 029.jpg
04.19.2007, 11:47 AM
Do you mean that you can use the Kyosho spur and Mike's mount without relocating the rear diff? That would be extremely cool!
riceman
RC-Monster Gold
riceman's Avatar
04.19.2007, 11:53 AM
That would be cool if I didn't already drill out my chassis:019: As for the Lipos I ran at my track with 2S and it was plenty fast. I have room to gear up if I need more speed. But as it is, it is as quick if not faster than any of the other 10th scale vehicle at that track.
IBJAMMIN
IBJAMMIN's Avatar
04.19.2007, 12:03 PM
No you still have to redrill the holes with the wider plastic spur gear your center diff is going to be about 2mm longer I moved my diff over in the chassis and relocated all 4 center diff holes to get the battery closer to the centerline and make room for a 4s later but you can get away with just relocating the rear holes in the chassis. :)
