I thought about the effects of the needed feedback for the controller, but I figure it would clean up the signal if anything. If the signal is not a perfect spike (noisy on the top), then these would effectively shop that noise off - kinda like how FM modulation works in RF. However, because there would be no actual "peak", the signal might resemble a square wave more than a spike...
Cool, would that part be something like what the Novak trans-cap uses then? In the little pic, they look very similar.
Wouldn't 25v not be enough though? Wouldn't we need something at least like 30 volts or more?
