gixxer
gixxer's Avatar
05.03.2007, 04:06 PM
if you are going to run 4s, you should set the cutoff in the 12-12.5volt range.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
str8up
BL savage in the works
str8up's Avatar
05.03.2007, 04:40 PM
Well i guess runtime depends on how long the 5000 will last?
And as far as the cutoff, i have the nomadio with a voltage sensor and it will alarm me when the lipo gets below 12v or so. I can also set it to do an action on the event of the alarm (like disable throttle). Figured i would make the radio do the work to take less off the esc. My thoughts were the less the esc has to do the cooler it will run.
  Send a message via Yahoo to str8up
