zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.04.2007, 01:52 PM
Well, these small high power ultra capacitors are relatively new. Don't ask me why no one has tried it, as you can see, not very many ppl are interested in them. We won't know how well they perform in real-world unless someone tries it, I am.
As for your connector arcing, it WILL happen when there is no voltage in the caps, if they are charged, it won't happen. The Quark itself self discharges the caps, no need to do it. Your fans will only run for like a second.
GriffinRU
05.06.2007, 12:47 PM
Why nobody? I used them they are great but they are not cheap. Old link
zeropointbug
Z-Pinch racer
05.06.2007, 01:28 PM
hmm doesn't say that you are using ultra-caps. Which brand/series did you use, and what did you use them in?
GriffinRU
05.06.2007, 01:46 PM
same caps
I was using BPAK0058 E015 58F 15V on E-Maxx.
zeropointbug
Z-Pinch racer
05.06.2007, 02:40 PM
Oh, you were using one of their modules? IC How many caps total did it use? It shows 58F, but you would need alot of caps to get that, considering the series requirements for voltage. What setup did you have? Little more info?
GriffinRU
05.06.2007, 06:20 PM
Modules selector
My module pdf
6 350F Ultra Caps with balanced circutry and wiring for series connection.
