bdebde
That's All Folks!
bdebde's Avatar
05.08.2007, 03:22 PM
I suppose it could be possible, the heavier the vehicle the worse it will be. One thing that will likely help; only set the brake power on the ESC to what you need to stop your rig in a reasonable distance and no more. Also, don't use drag brake if not needed. Had lots of heat with a mamba 25 in a mini LST running drag brake, switched to a quark 33 and no heat problems
