RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
07.08.2005, 06:27 AM
Originally posted by Serum
Do not use fuses. They can harm your controller (blow it up) when the controller looses connection with the batteriepack. (the reason all the schulzes die is because of a loose connection) when you brake, the energy is stored back in to the batteries, (it uses the low internal resistance of the batteries to brake) once the connection with these batteries is lost, the energy can no longer be stored and it is very likely it kills the controller.
I don't know what a controller does when it looses power though, but if it looses RC it brakes as hard as it can.
I would never put my controller in that risc of a fuse. (how odd does that sound?)
Agreed 100%. If you simply rolled your car for a 100ft with no battery plugged in(but the motor and controller attached), I think you would most certainly blow the controller. The brushless motor acts like a generator(generates power) and with no place to put the power, the controller must absorb it.
