MetalMan
MetalMan's Avatar
05.11.2007, 03:49 PM
I will gladly be awaiting those caps :).
That motor temp doesn't sound too good... My thoughts tell me that it's toast, since after about 180 deg. on the outside the inner temperature will most likely be hot enough to start de-magnetizing the rotor. I'm curious if the caps caused the excessive heat in the motor, which might be from their ability to allow for higher currents to flow through the FETs than is possible without them. Or, maybe the motor was just undergeared.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.11.2007, 04:13 PM
WOW, for the nice setup with the caps AAngel!
WHOW, on the Quark trouble, that is a serious bummer! And yeah, what the BLEEP are the odds of that happening just now? I find that strange that there would be 'bad' caps, seems rare to me.
So you did notice a big difference with the MM with those 4 extra caps? Really like how you did that man. thumbs up
I guess I should pay you for those caps, PM me.
