GriffinRU
05.13.2007, 08:32 PM
Motor takes the abuse.
Power goes to batteries if voltage higher then... and you can skip diode drop if utilize FET's instead. And as I said it is possible, but I haven't seen one yet from known brands, except claims by Novak on brushed ESC and mtroniks for all.
If you see direct connection between batteries,caps and FET's then such circuitry doesn't exist.
