IBJAMMIN
IBJAMMIN's Avatar
05.15.2007, 01:15 PM
I would go for the Hyper7 parts and hop up's are avalable.
Motor mount? you can get mikes ofna mount.
Spur? The Kyosho 46t plastic spur should bolt up to the ofna diff with a mod1 pinion.
Motor? There is many options to go with I will let someone with more buggy knowledge fill you in on that. 14.8v to 7.4v it's going to be hard to find a motor that will work good on both voltages.
Battery mounts just look around at some of the conversions here and see what works.
15min of runtime should be very easy on 4s.
