Cartwheels
05.15.2007, 10:18 PM
[/QUOTE]I might try popping the sink off of a MM and putting a better sink on it.
[/QUOTE]
You could use a larger fan instead. This one that I use is a 30mm fan. Here is a pic. It hangs over a little but It covers more area and blows more air. It is held in place with 2 screws (the zip tie is holding the ESC in place).
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.15.2007, 10:47 PM
Have you mounted up some extra caps to your MM yet?
Cartwheels, did you get those capacitors from AAngel? Or did you buy your own?
