Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
neweuser
neweuser's Avatar
05.17.2007, 11:02 AM
Originally Posted by ssspconcepts
Wow. Nice ride. You did a good job setting up the electronics. Though I am surprised that heat is an issue when running 5S. The Quark 125 is rated at 6S and you have a robust heatsink and fan setup...
I can run 5s with no issues, but it gets a tad warm compared to the 4s. And the Quark is rated for 6s, but cannot do it well. 5s is about the most you want to go on the quark. If I hada motor with a lower kv, it would be even better, my current kv is 2200...which is the reason why it runs warmer than my likings.
ssspconcepts
ssspconcepts's Avatar
05.17.2007, 11:12 AM
Thanks. Just curious...what are your runtimes on 4S and what is your approximate top speed?
neweuser
neweuser's Avatar
05.17.2007, 11:14 AM
On 4s, about 25 min maybe more, top speed most likely 30's, not quite sure. 5s, I get about a half hour, top speed a little more maybe like upper 30's.
ssspconcepts
05.17.2007, 11:42 AM
Does anyone know if the NEU 1515 series of motors fit on the stock emaxx motor plate? Or, is it necessary to custom drill mounting holes?
neweuser
neweuser's Avatar
05.17.2007, 11:45 AM
I could check when I get home if they line up? Or if someone knows right off hand.
ssspconcepts
05.17.2007, 11:52 AM
I would APPRECIATE it SOOOO much if you would check and let me know. Thanks.
neweuser
neweuser's Avatar
05.17.2007, 11:54 AM
You bet, I'll be home by 6:00PM tonight and will take a look.
knotted
05.17.2007, 11:56 AM
I have a 1521 on my Savage, it has the standard holes. The case is the same as the 1515 only 0.6 inches longer. It will bolt up fine.
