MetalMan
MetalMan's Avatar
05.18.2007, 01:07 AM
I got my caps in on Wednesday, also a very fast delivery :005:. Unfortunately I haven't gotten around to soldering them up yet, but I am hoping to do that tomorrow. And, I do have some real testing to do: 7XL/MM on 5s2p A123 geared for ~41mph (or I can drop the spur teeth and run it at 47mph), and I have my Hyper 8, which is now running a Neu 1512 2.5D and MM, on Maxamps 4s 5000mah Lipo geared 18/46 (WAY too high, estimated 48mph top speed). The Hyper 8 is geared high enough that it cogs VIOLENTLY on startup about half the time, however, the MM has not yet thermalled even without a fan over it.
GriffinRU
05.18.2007, 02:47 PM
Finally capacitors being discovered by RC!!!
But keep in mind they only good if they close to FET's, very close, almost mounted on top of them. Cap per bank of FET's, otherwise you add inductance which doesn't help you at all, actually will cost you at higher RPM's...
While selecting capacitors in addition to ESR and Voltage check for 125C version.
