Maxxman
05.20.2007, 05:19 AM
it doesn't really matter much,
but i may add some as many people around here, including S&T as you mentioned as well as others, say that it is better to add some if you can.
the capaciters in the Quark are 330uf low esr caps aren't they.
Also in some ways having squared corners would be better than rounded as you would have more material, therefore theoretically a larger surface area and machining costs a bit lower.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.20.2007, 01:58 PM
They are low-esr type yes. I have to go for edge chamfer instead of fillet. Chamfer is the edge taken off, usually at a 45' angle. Something that small, it would still look like a fillet anyways.
zeropointbug
Z-Pinch racer
06.07.2007, 07:52 PM
Here is the case with Edge Chamfer instead of Fillet. Also, the bottom is modified to make it easier machined. I asked Mike if it were a good idea to chop the bottom off of it and use his heatsink for bottom and mouting, to reduce costs of course.
Name:	Quark v 3.JPG
ID:	3040   Click image for larger version
Name:	Quark v 3 (2).JPG
