Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Patrick
Patrick's Avatar
05.22.2007, 05:51 AM
Originally Posted by luvsrc
yes I'm using the finned version my 16 tooth pinion on my standard revo diffs is the lowest pinion i can fit in my gorillamaxx single speed tranny without grinding the finns which I will not do it anyways, you can use the buggy version or even the truggy version which lowers the gear ratio more so all you have to do is put a bigger pinion on it, the 18/51 on buggy gears will be the same with my 16/51 on a standard revo diffs
Oh, ok. I couldn't get a 16t pinion to fit on mine (2 speed e-maxx transmission and stock motor plate).
I'm trying to figure out why yours will fit and mine won't, and the only thing I can think of is if you have a gorrilamaxx motor plate, that sits the motor in a slightly different place?
