chilledoutuk
05.26.2007, 12:18 PM
personally i think it would be easier to jus cut the legs on the caps and then put a bunch of caps connected externally should work just as well.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.26.2007, 01:09 PM
Oh man AAngel! :019: You are having such bad luck with your controllers! I feel for you man! I really do!
Unfortunately, you probably damaged other parts of the ESC itself. That's what Frank told me, and just said for me to send it in for replacement.
I thought you were going to put the caps on it like I was going to? :032:
zeropointbug
Z-Pinch racer
05.26.2007, 01:11 PM
That looks pretty good Suicideniel.
Please don't tell me that is your antenna wire running along in that pic?! :eek:
05.26.2007, 01:46 PM
Cheers. One of those wires is the antenna, but believe it or not there is no glitching or anything, since the radio was ment for a plane the aerial wire is about 2 foot long- had to bundle it up abit (wouldnt dream of cutting it down). I just want some good weather to take it out and do a proper test run....:007:
zeropointbug
Z-Pinch racer
05.26.2007, 01:50 PM
rainy UK... :024:
05.26.2007, 01:56 PM
rainy UK... :024:
Same old same old. When Im working its usually beautiful and sunny outside. When its my day off the sky turns grey- it might not actually rain, but its so gloomy I wouldnt want to walk all the way to my spot then risk it start raining on me. No problem though; its a rollover on the lottery tonight so when I win £7,000,000 I'll just buy a nice barnconversion or bungalow with a few acres of land & build a giant glass roof over the top, that way the grass still gets sunlight, and I can drive the truck without getting wet.:027:
jhautz
jhautz's Avatar
05.26.2007, 02:11 PM
AAngel... Before you start removing the caps, call S&T. I've heard a few mention that they warantied the controller even tough it had been modified. Worth a try before making more mods IMO.
to make it...
or break it...
Silent...But Deadly
