gasshead
j-womp
gasshead's Avatar
05.27.2007, 01:31 PM
hey if you can come the upcomming race. i wont have a revo but a jato with a purple and black musting GTR body. i do make every race i never do good but i'm there to have fun.
  Send a message via AIM to gasshead
Cajun
11.23.2008, 06:42 PM
Hey guys, been a while since I posted. I finally did the rebuild on my E-Revo and thought I'd post up some pics of the new/old set up....
I replaced the BEC with an RX battery and that really simplified the wiring harness
I used a Blue Groove conversion to replace some of my homemade aluminum brackets and mounts with carbon fiber mounts
RC-Monster motor mount
RC-Monster mod1 pinions
MaxAmps 4s 6000mah
1500mah RX hump pack
Wanderer 9XL
Mamba Max
RPM corners
Tony's Screws as always
new blingerific body
plus all the original mods from build V1.0
I also finally fixed all the problems that were incured when I decided to see what it would take to break it last spring. Surprisingly, it wasn't nearly as bad as I had originally thought. There was one slightly bent push rod and 6 or 7 rod ends that needed to be replaced. That's it.... I haven't weighed it yet, but V2.0 should be significantly lighter over the original as well. I dropped all the aluminum mounts as well as the wing and mount and went to the 4s instead of 14 subCs. Here's a few pics:
