MetalMan
MetalMan's Avatar
07.11.2005, 02:47 PM
That's a lot! Normally 14 cells is considered the maximum to run on the 9L.
But if you are fixed on using that much power, then 5s will be fine. That would be more like 17cells though, with a lot less weight. 6s would be like 20cells. I would strongly reccommend that you use 4s on the 9L to keep the temps. down, or just go with a 10L for use with 5s Lipo.
