Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
jamesbernatchez
The Brushless Wonder
05.31.2007, 10:09 PM
Originally Posted by BrianG
I have a CRT.5 as well and absolutely LOVE the way it drives! However, since the selection of hardened pinions to use is limited at the moment, I was stuck using a hardened 16T pinion and that was geared too high. So, it's on a shelf right now also awaiting a plastic spur.
A 12 or 13T pinion should work well on either of those motors, assuming the stock Mod1 pitch.
If using the 4600, I would use 3s if it's available. If using the 5700, 2s should be fine.
Being so small, the CRT.5 is an easier conversion and can use less expensive components.
Thats kinda why I want to build this one first.
As for the Mod1 pinions, which bore do I need for the Mamba motors? 1/8th, 4mm, or 5mm?
Thanks :027:
I only have crawlers...finding a brushless project to begin though :)
  Send a message via AIM to jamesbernatchez
