jollyjumper
RC-Monster jumper
jollyjumper's Avatar
06.03.2007, 10:05 AM
this one is for all mugenite's:
Originally Posted by tony1034
Here are some build tips for guys putting together a MBX5T (or buggy)
The biggest tip would be prepping the diff cups and double-gasketing them. Using like 3 different grit sandpapers (I use emery cloth) you want to sand the cups until they’re smooth as glass. I use 320 grit, then 800 grit and finally 1500 grit. Place the paper on a perfectly smooth table and hold the cup on the paper. Swirl it around in a figure 8 pattern. The idea is to get the cup perfectly smooth and flat. When you go up to 800 grit, you’ll quickly see the plastic get very shiny smooth. If you didn’t go long enough on the 320 grit, you’ll clearly see it. I then do a quick run with the 1500 grit and they’re dead straight. What this does is ensures the cup won’t leak against the ring gear or spur gear. Most people blame the leaky Mugen diffs on the o-rings, but 95% are at the cup (just take two cups and face them together and see the light in between them as you rotate them face to face). Remember, the cups are not machined, they're molded. Then double up the gaskets (Part # C0257). I use my screws 2mm longer than the manual and tighten up. They’ll NEVER leak from the cup (Tip comes from Chad Bradley).
I also have thicker 5mm (S5) o-rings for the out drives. These are tighter than the stockers. The real key is to use grease on them (the thicker S5 o-rings or the stock S5 o-rings) and in the slot on the outdrive shaft. Of course, do NOT use the small S3 o-rings.
I use the stock Mugen brake linkages so I put a slight z-bend in the upper rod to get it fit right. You won't be able to easily adjust the rear brake bias with the z-bend, but remove the small 2x10mm screw and twisting it is very easy. I usually get it set right and then adjust the front in or out. I know most guys love the Kyosho linkages. If you’ve had the Kyosho, you may like it and want to fit them on the Mugen. The Mugen uses fuel tubing where the Kyosho has those little springs. I’d like to change mine over to try the springs, but don’t have a Kyosho to see how it goes. Maybe someone else that switches can post pics.
The kit should also have shims to get the ring & pinion mesh set. They go outside the 8x16 bearings on each side and just add pressure to get the ring gear closer or further away from the pinion. They are 14mm x 16mm by .1mm thick. On the buggy, I always used two on the diff cup side to push the ring gear away from the pinion. But I've heard that the new 46/10T ring & pinion on the MBX5T doesn't need them. Regardless of what anyone else uses, always check the backlash on your car.
The rest of the car goes together like butter. New shocks are SWEET!
Best regards,
Tony P.
This post has been edited by tony1034 on Aug 18 2006, 04:58 PM
OK, so let's put this shock end issue to rest. I just measured the shock bodies, shafts and springs from my X5T shocks and my old MBX5 shocks. I also measured the shock end hole depth.
DATA ....LOL
Shock Rod End Hole Depth - 11.15mm
MBX5 Front Shock Body - 42.33mm
MBX5 Front Shock Shaft - 52.63mm
difference - 10.30mm
Rod end to top of shock body height: -0.85mm
Shock Spring - @70mm
MBX5 Rear Shock Body - 54.06mm
MBX5 Rear Shock Shaft - 64.71mm
difference - 10.65mm
Rod end to top of shock body height: -0.50mm
Shock Spring - @90mm
MBX5R/T Front Shock Body - 47.33mm
MBX5R/T Front Shock Shaft - 59.63mm
difference - 12.30mm
Rod end to top of shock body height: +1.15mm
Shock Spring - @75mm
MBX5R/T Rear Shock Body - 59.05mm
MBX5R/T Rear Shock Shaft - 71.65mm
difference - 12.60mm
Rod end to top of shock body height: +1.45mm
Shock Spring - @100mm
So.....If you screw the rod ends on all the way on the old MBX5 shocks the piston, locknut and shock shaft are below the end of the shock body by a very small amount. The piston would be very noticable down in the body and if you looked at it from the side, you would not see the nut or shock shaft.
But on the MBX5R/T shocks, the piston would be noticably below the end of the shock body, the top of the nut would be about flush and the tip of the shock shaft would be above by a very small amount (1.15mm in the front and 1.45mm in the rear). You might just barely see the top of the nut looking at it from the side. So obviously I did not get my shock rod ends on all the way because my pistons are flush with the top of the bodies and the nut and shaft completely poke out and compress the bladder. I will have to thread each rod end on several more turns to get them correct.
In looking at the old shock shafts and the new ones, the way the threads are cut into the shaft is different. On the old MBX5 shocks the threads are cut all the way, nice and deep until they end. But on the new shafts, the threads are nice and deep at the tip, but then gradually taper off as they go up the shaft. This makes the shafts much stronger and less prone to breaking. +1 for Mugen. BUT...it will also make tightening up them rod ends a tough son of a beech them last few threads...LOL :brickwall
Everybody that didn't get the ends on all the way like me, happy busting out the pliers and twisting the skin off your fingers ....HAHAHA
Best regards,
Tony P.
Servo-saver issues with blowing servos:
Some guys have been having issues with the servo-saver locking up on the MBX5T and MBX5R (use same servo-saver). Before assembling the servo-saver with the spring, make sure the upper plastic piece slides up and down the tube smoothly. The fit is a bit snug on this new tube/plastic. I polished my servo-saver tube and then use a dry lubricant (Dow 557 from mcmaster.com). You can also use some graphite. Don't use any lubricants that contain oil such as WD-40 as dust will adhere to it and bind it up. Then make sure that the servo-saver works. It should cam over if you try to turn the wheels and hold the servo link. Finally, make sure you set your EPA (both left and right) with the arms level. I set mine for maximum and then back off two clicks on my M8.
Enjoy!
Best regards,
Tony P.
losi 8ight-t
xray xt8
jollyjumper
RC-Monster jumper
06.04.2007, 01:28 PM
Originally Posted by Serum
What do these clubs think of the a123 cells? or are they to stubborn to see they don't burn like lipo's?
well, he'd need like atleast 8 cells for 4s2p and there 70gramms a piece right?
that also a rather heavy pack to put on one side IMO.
losi 8ight-t
xray xt8
Papa
Papa's Avatar
06.06.2007, 09:45 PM
Its been awhile since I've been around, but I thought I might show off my second 5t. Whats happening fella's? I 've been racing alot. I love my MOOOGENS I run both buggy and truggy these days. Yeah yeah yeah.... I know its not Electric but it sure is fun.:030:
moogenite
Let non survive!
moogenite's Avatar
Talking 06.07.2007, 03:41 PM
hey there papa,
i see you have bce chassi', how is it?
is it a x5t or xx5t?
:032:
Papa
Papa's Avatar
06.07.2007, 03:44 PM
xx5t the longer one. I have not noticed much of a difference over the stocker. I am still making the podium most of the time.
moogenite
Let non survive!
moogenite's Avatar
06.08.2007, 10:55 AM
does it require a longer rear cvd?
mid-mugen mods
moogenite
Let non survive!
moogenite's Avatar
Talking mid-mugen mods - 06.10.2007, 07:09 AM
thinking about the brace's:
Photo Sharing and Video Hosting at Photobucket
will install the holders from start:
rchippie
rchippie's Avatar
06.13.2007, 01:44 PM
Do you have a link to these parts ?.
REAL MEN RUN BRUSHLESS
Serum
Serum's Avatar
06.10.2007, 07:31 AM
I thought you said you where not worried about the braces?
moogenite
Let non survive!
moogenite's Avatar
06.10.2007, 08:00 AM
these will also flex, like the plastic ones.
most of the pro-spec owners run the plastic braces anyway.
also the prospec braces i now dont have to pay for, i wouldnt of used them anyway.
jollyjumper
RC-Monster jumper
06.13.2007, 01:18 PM
braces with dampers in them are being used in real racing cars alot.
so it will be sweet to see them in the mugen truggy.
wonder how they will act?
losi 8ight-t
xray xt8
moogenite
Let non survive!
moogenite's Avatar
06.14.2007, 06:26 AM
http://www.mid-mugen.de/
jollyjumper
RC-Monster jumper
Talking 06.19.2007, 03:52 PM
so we started the build of moogenite truggy,
it looks like we will have to change plan to single left mounted batt, right rear motor.
cuz we cant put the diff exactly in the center of the chassis, there no room for the front brace.
also ( didnt get them yet) but with the special chassis' brace's it looks like the wont be room for a motor like neu 1515 or somehing along those lines, if it where to float over the diff.
losi 8ight-t
xray xt8
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
06.20.2007, 02:36 AM
aahh ill be watching this thread closely!! Also planning a brush less conversion.
rccna.com
moogenite
Let non survive!
moogenite's Avatar
06.23.2007, 07:44 AM
its me, sweet x5t pro-spec.:D
i'm thinking of using lehner 2230 motor in my truggy.:p:p:p
