AAngel
06.02.2007, 08:18 PM
What were you running that in and with what motor? The HV110 is a nice controller and will handle high voltage, but it's current draw rating isn't that impressive. I believe that it is only rated to 110A continuous and I'll bet that the max current handling isn't much more than that, with this particular controller. The application for which this controller was designed will hit over 100A but the spikes aren't there like they are when used in a truck or car. Even the MM will handle up to 300A spikes, IIRC and so will the Quark.
Were you using motor braking or did you have mechanical brakes?
lutach
lutach's Avatar
06.02.2007, 09:08 PM
I was using it in my truck with a Hacker C50-XL or the ION-X motor and 10 A123 cells. The brake was off. I did run the truck 2 days ago for a sort test and it ran fine. Man this is just crazy. My Kontronik Jazz 55-(Something)-32 stopped working, but it lasted longer than the HV110. My Kontronik 40-(Something)-32 only blew the capacitor, but it also lasted longer than the HV110. The BK 3695 cogs like crazy, but it will go back in the truck. I was hoping to see my truck go around 80MPH or so. I can only beg CC to sponsor me with one of those SHV controller. That way I can wire my DeWalt packs in series and see what 72 volts fells like. LOL.
lutach
lutach's Avatar
06.02.2007, 09:36 PM
AAngel,
You mentioned IIRC. Is that a ESC or something else?
jhautz
jhautz's Avatar
06.02.2007, 09:43 PM
IIRC = If I Remember Correctly
to make it...
or break it...
Silent...But Deadly
