AAngel
06.05.2007, 12:52 AM
jhautz, I've never done what you have on a Lehner before, but I do know that it takes heat to desolder; and if your motor got hot enough to desolder the connections that you made, the desoldered connections would be the least of your problems. Obviously this is not what happened.
In what manner did you do the Y connection? Without having seen it, all that I can suppose is that in your effort not to overheat the little 3mm connectors on the motor when soldering, perhaps you made a series of cold solder joints that literally fell off. Or perhaps you used some solder that had a really low melting point. I know that I have some silver bearing solder paste that melts with the heat of a match.
jhautz
jhautz's Avatar
06.05.2007, 01:11 AM
I just used some solder that I got from the LHS. I use it for everything and never had an issue. The guy at the LHS told me to gt it, that it was "the best" solder they carried. It sure doesn't seem to be a low temp solder. I usually have to run my soldering station all the way up close to 900 degrees to get a good fast solder joint. I don't think the solder is the problem, but if it happens again Ill have to see about finding some "high temp" solder. Anyone know of any?
http://www.lehner-motoren.com/downlo...use_s10-22.doc
This instruction sheet shows a diagram of the traces on the back of the motor. The breaks in the traces marked "D" and "S" are the spots where you bridge the gap with solder to make the connection in either the "D" configuration or the "star" configuration.
I removed the solder from the D connections and bridged the S connections.
I am wondering if maybe its possible that I didn't use enough solder on the bridges and they heated up locally from the resistance and melted themselves. The weird part is that it just stopped. All 3 melted at exactly the same time. Not sure if I can swallow that, but I don't have a better explanation. I used a little extra solder this time so hopefully that fixes it if that indeed was the problem.
I'm hoping that someone around here has some experience doing this. Its the first time I tried it. I think that CHC did it once for his High Voltage project. I'm just hoping this doesn't have the same disastrous ending as his project did.:032:
to make it...
or break it...
Silent...But Deadly
