RPM for MGT - save your dough -
06.07.2007, 08:11 PM
It isn't bad in any way, it does what it says, but the stock ones do the same and cost less. Also, there are issues with suspension travel limits with the RPM arms, you need to grind them, or Dremel the tabs off the skid plates to allow full droop.
Not sure if that has been fixed, but I switched to the stock ones with an older truck and was happy with them.
