AAngel
06.08.2007, 05:19 PM
zpb, I did do the mod, but it is reversible. I've gotten the AA loose before, even from smt chips.
I wonder if there is anything on the controller that would be hurt by acetone. If not, that would be a good way of weakening the bond of the AA. I've used it to separate parts before. A good soaking in acetone overnight should do the trick.
The heat build up of the top set of FETs is still weighing on my mind. I'm going to have to wait and see how it runs. If the mod works as well for me as it has for everyone else, I should be OK.
As far as the Neu goes, I was hoping to hear the good ole "we've shipped you a new one already." Or better yet, "we are out of 1512s, how about a 1515 1Y or 2.5D." LOL
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.08.2007, 06:00 PM
What epoxy did you use then?
The heat build up on the tep FET's... like I said, any power bursts will have a larger temp differential than the average temp difference, so higher thermal transfer the better. But it is harder to do the top set i guess. The best way would to just use the case I designed really. You just apply thermal paste, and slide in on and clamp her down, there goes all heat sources down the sink. :005: HEAT sink that is.
