06.10.2007, 06:48 PM
I reckon a Gmaxx strap from one end of each battery box to the other would be fine- bolt it onto the aluminum end caps either on the inside or out side, depending on how snug a fit the batts are in their boxes. Do you have the batts already- a pic would prove useful in seeing how tight a fit they are.
That and we like picks around here, as you should know..... :)
rchippie
rchippie's Avatar
06.10.2007, 06:52 PM
Yes i have the batterys. They fit very snug in the boxes, no slop at all . There is 1/8 of a inch of foam rubber all around & underneath the batterys. The foam is not in the boxs in these pics.
REAL MEN RUN BRUSHLESS
