Knowing You're Hooked on RC: Priceless...
06.12.2007, 11:28 AM
I think he means if you plugged a 2s A123 directly into the Rx's Batt slot, it doesn't run it very well.
Doesn't the 5700 handle up to 12 NiMH cells? That is 14.4 volts. 4s A123 is only 3.3v*4 = 13.2v, which is less than the NiMH's rated voltage.
What I am probably going to do is cut the Dewalt pack up into two 2s packs and two 3s packs. I'll run a 3s pack mostly in the Rustler, and if it is safe, run a 4s setup every once in a while. For my boat, I'll put a 2s on the BEC side of the ESC, and probably a 2s on the other side too, but use a 3s on the non-BEC side when I need to race my neighbor's Villain EX (completely stock, 12 Radio Shack 3000 cells:005:). Theirs is fast, being new and all, but I have specially designed carbon fiber props, lower turn E-Maxx (non Marine) motors, more water cooling, better batteries, and more batteries. I should have no trouble beating them:027:.
@CPB, The Titans may get hot, so I would at least check them during the middle of a 2p run. I'm just going to do what you suggested, running 5s1p, then just switching that set out for the other set. If it is too hot, I'll let it cool some.
Does anyone know how A123's and water react? What if I were to flip my boat and some water gets in around the cells?
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
Z-Pinch racer
06.12.2007, 01:16 PM
Yeah, 2s on the esc's BEC should work great, better than a 7.2 pack.
I am going to run two packs as well then... and switch.
I thought the Villian EX was water proof? I think you can roll it, dunk, and dive it, at least that's what I thought.
So I think it should work great then, over volting it a little *Titans can handle it, in fact they are a couple turns more coils than the maxx Titans) but it will be lighter.
06.12.2007, 04:42 PM
The Villain EX is NOT waterproof. It has foam floatation, so it won't sink, but it can get water in it. It has a waterproof box for the electronics (not batteries), but water can still get in if you flip it and it just sits there for a while. Here is what happens when you flip it.
The Titans can handle the voltage, the higher turn ones in your new one will handle it better probably, but their life will be shorter than if you just ran the recommended voltage.
I read somewhere that EVX's have different voltage limitations from ESC to ESC, and if you put too much voltage to it, it simply won't drive the motors. Then you can drop a cell or two and it works just fine. I heard of someone on the Traxxas board, rupert I think, who had one that could do up to 18 cells:036:. I haven't tested my EVX's voltage limit, so I don't know if it will do more than 7 cells. My packs would usually read about 9 volts when fully charged, so mine should be good for up to 18 volts, I hope.
Slash 2x4 LCG
Two Slash 4x4s
Rustler
Z-Pinch racer
06.12.2007, 04:47 PM
Well I better take it easy then...
Yeah, last year I had an on road 1/6 scale car, dual EVX's, dual dewalt 820 motors, I ran 6s A123, although, straight off the charger it would sometimes cut power, once the motors turned over for a few seconds the voltage came down enough for it to run fine.... and did it ever! :017: Prossibly 1000 watts from two brushed motors, they were very durable.
Z-Pinch racer
06.12.2007, 05:56 PM
Silly me, correction... 5s2p A123 is ~180 grams lighter than 12 cells NiMH.
So if 5s2p fits inside the boat, I might just go that route, I will see.
06.16.2007, 07:52 PM
How hot do the M1 cells get? I just got back from the lake, running my Villain on 14 GP3300s, and those cells get way too hot to touch after a hard run. Of course, the batteries aren't exactly spring chickens, being about a year old (the 19th will be their birthday:cool:), and being run a lot in my used-to-be-brushless Maxx, the batteries didn't have an easy life, so they could have developed some resistance that will make them get hotter than they should.
I just don't want the M1 cells to melt a hole in my boat and sink the whole thing:036:. I read about them a bit in the newest issue of Popular Science, and it tells how they work and everything, also saying they can withstand heat up to like 400* without being damaged, so durability doesn't seem to be an issue.
Thanx,
Brijar!!!
Slash 2x4 LCG
Two Slash 4x4s
Rustler
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
